the Meta tag remove when I m try to save html page or switch to source tab . I enabled the config.EnableXHTML true so problem solved but I want To disable Xhtml .
is there any way to keep meta tag witout enabling XHTML ?
I need charset=utf-8 in IFRAME , but FCK remove the META tag as well as body or head tag , how ? which JS script related to cleaning HTML ? HELPPPP ME please
