I've been having problems off-and-on with the last couple releases and now again with the FC preview. I run a development version on my local XP machine with IIS. On Firefox, I keep getting username/password prompts when loading the editor. Once I start getting it, I've not been able to get rid of it. Doesn't seem to be a code issue that I can determine, since a file comparison between two versions, one that does it and one that doesn't often won't show any difference. And I can take a directory that was not doing it, rename it to something else, and point to that one, and then it will start coming up. Renaming it back to the original doesn't seem to help....once I start getting the prompt, I can't find a way to get rid of it. Any ideas? I only get it on CF5, running on CFMX does not seem to cause it, nor do I ever see it in IE.
Otherwise, the new version is working fairly well for me. Still some crashes in Firefox but definitely far better than RC3.
RE: Issue on CF5
RE: Issue on CF5
RE: Issue on CF5
RE: Issue on CF5
