I am working on FCK editor (in Inernet Explorer 6) using Java and Jsp.
I am not able to copy(using Alt+Print Scrn) and paste(Ctrl+V) clipboard images.
When I try to do so I am getting a "Paste-Web Page dialog" window with the following message.
"Because of your browser settings the editor is not able to access the clipboard data directly. You are required to paste it again in this window."
But still i am not able to paste it in the new window also.
Can this be done using the editor ?
If so ,should i do any changes in the configuratuion files?
Re: How to copy and paste images from clipboard
file:///C:/DOCUME~1/SP/LOCALS~1/Temp/moz-screenshot-11.jpg
This worked nicely but I couldn't figure out how to change the default location for the files (to put on a thumb drive). Now what I'm wondering is whether there might be some way to trick Firefox and FCKEditor into uploading the image. I suspect that Firefox allows this access to the local file system only when editing local files but I'm not sure. Still it would be quite useful to be able to paste images into a page and then either auto-upload the images to a server (DekiWiki is the server platform that I have in mind at the moment) or at least work through a file upload dialog that points to the temp files that Firefox created.
Does anyone have any thoughts on this?
Thank you.
