Hi.
How is CarriageReturn suppose to work?
It' would be nice if FCKeditor produced the same in IE and FF (Gecko). But it does not.
Even if I set:
FCKConfig.UseBROnCarriageReturn = false ;
Firefox still insert "<br />".
IE insert "<p> </p>" on CR and "<br /> on SHIFT+CR.
Is this supposed to work similar in IE and FF (Gecko) or not?
If not, is this issue going to be fixed or is there a patch available?
Even if I set:
RE: How is CR (CarriageReturn) suppose to wor
One question though.
Is it not possible to implement some sort of event listener ... and then when the CR key are pushed down then insert either "<br />" or "<p> </p>" depending on the setting in the ...config.js file.
In IE:
document.onkeydown=docKeyDown;
And then use: e.keyCode
In FF (gecko):
document.addEventListener ('keypress',docKeyDown,true);
And then use either:
e.which or e.keyCode
I belive both gives same keyCode for CR in gecko.
And then eventually use for IE:
e.cancelBubble = true;
e.returnValue = false;
And for Gecko:
e.preventDefault();
e.stopPropagation();
to prevent whatever is default inserted on CR and then force either "<br />" or "<p> </p>"
I guess it may not be that simple though... because if it was then it would probably be there allready.
What exactly is the problem that this is not doable?
Regards
Ref. the release on ver 2.1.1:
In the /editor/_source/internals/fck_1_gecko.js file (extract of some of the code, see end of post) I found a wrong reference to a variable in FCKeditor:
One place it says:
FCKConfig.UserBROnCarriageReturn
I belive it should be:
Could this be related to the bugs that where reported when the code was implemented in the 2.1 version?... and that laiter was commented out.
Regards
Copy of some of the code below:
var oOnKeyDown = function( e )
// FCKDebug.Output( 'Which Key: ' + e.which ) ;
// START iCM Modifications
// Need to amend carriage return key handling so inserts block element tags rather than BR all the time
if ( e.which == 13 && !e.shiftKey && !e.ctrlKey && !e.altKey && !FCKConfig.UseBROnCarriageReturn && !FCK.Events.FireEvent( "OnEnter" ) )
e.preventDefault() ;
e.stopPropagation() ;
// Amend backspace handling so correctly removes empty block elements i.e. those block elements containing nothing or
// just the bogus BR node
if ( e.which == 8 && !e.shiftKey && !e.ctrlKey && !e.altKey && !FCKConfig.UserBROnCarriageReturn && !FCK.Events.FireEvent( "OnBackSpace" ) )
// END iCM Modifications
