I have just started using this program and have been trying to figure out my options with this problem.
We sell products that come in different sizes, but not all have multiple sizes. Some come in one size only.
These product have the discrption, but there is no where to have the size listed like the other products. The products that come in multiple sizes have a Product Options/Sizes listed on their page and then you select from the multiple sizes. When I try to put in the one size for the other products, I will go into edit, scroll down to Product Options where Sizes are, select the product size and hit Add Option. I will then be redirected to the admin page where an error message appears and reads:
Failed to update product.
I then tried it again and instead of hitting Add Option, I hit Edit Product and received the same error message.
How can I have the single size listed like the multiple sizes of the other products? The reason I want to have it like this is because most of our products come in multiple sizes and because of this, the sizes are not mentioned in the text. The sizes show in the Product Options area. We want all of the products to be listed the same, but we can't have Product Options listed unless they come in multiple sizes. Is there any way around this?
