In Firefox 3.0.1 when I switch to Source and then switch back to Editor, flash object's context menu properties are no longer accessible. This works OK in IE 6. Should I report it as a bug?
Fri, 08/01/2008 - 13:04
Re: Flash objects problem when switching to source view (Firefox
I attached an image to show that Flash properties are not longer available after switching back from Source view.
I'm testing 3.0.1 in windows XP and as I said it works fine, so this could be another of those cases where an extension messes up too much with the content.
I still have access to flash properties after switching back and forth from source to display with FF 3.0.1 (PC & Mac), but what puzzle me, is that the flash is displayed on your screenshot???
For me, I just have the dummy Flash placeholder, not even being the size of the flash movie.
Oh well, I noted, on the mac, that the first time I've gone back from source the flash displayed for half a second, before being replaced with the placeholder...
I guess there is an interesting thing here to dig...
Or are you expecting that magically we can guess what's going on in your computer?
Was happens is that when switching from source back to wysiwyg, the src is changed to about:blank.
As a start, you must remember that anyone else that it's using the Flashblock won't see your animation, so keep it in mind. And then, probably you should whitelist your domain if you want the flash object to behave as expected.
- IE Tab (i'm using version 1.5.xxxx)
- Google toolbar for firefox (i'm using version 3.1.2.xxxx)
If I disable them, everything works ok.
