A heads up for everyone who's upgraded to the latest and greatest firefox that just came out... It apparently breaks FCKEditor 2.0 Beta 2.
Apparently Firefox's "navigator.language" call returns an empty object by default (not a string for the language "en") This might be a bug (seems like it) of the newer Gecko engine release used by Firefox PR1, but for now, to fix it I changed the following code in internals/fcklanguagemanager.js.
Change the line:
var sUserLang = navigator.language ? navigator.language.toLowerCase() : navigator.userLanguage.toLowerCase() ;
to
var sUserLang = navigator.language ? navigator.language : navigator.userLanguage ;
// Firefox PR1 (gecko) has NO default language as the default. We'll set it to English.
if (sUserLang) {
sUserLang = sUserLang.toLowerCase();
else {
sUserLang = "en";
That should make everything work like normal again until this bug is fixed in Firefox PR1.
Change the line:
to
if (sUserLang) {
else {
sUserLang = "en";
RE: Firefox PR1 problem (and resolution)
http://localhost/espace/libs/FCKeditor/ ... gecko_1.js
http://localhost/espace/libs/FCKeditor/ ... startup.js
I have not tested it but I think you could also disable FCKConfig.AutoDetectLanguage and set FCKConfig.DefaultLanguage to make things work.
Piebe
http://localhost/espace/libs/FCKeditor/ ... gecko_2.js
http://bugzilla.mozilla.org/show_bug.cgi?id=259536
Simone
