I get that javascript error using IE5 and the editor doesnt spawn and display. I'm using the javascript connector to spawn the editorr.. I veriefied my paths as far as I know.. Not sure what is needed to configure this beta as the config files arent there anymore...
Version 1.6 works flawlessly using the ASP connector.. (waiting for the ASP one on 2.0). Something I'm missing or is the languagemanager not detecting my default language correctly?
RE: FCKlang not defined..
var oFCKeditor = new FCKeditor( 'myEditor ) ;
oFCKeditor.BasePath = basepath;
oFCKeditor.Height = 400;
oFCKeditor.Config['SkinPath'] = basepath + 'editor/skins/silver/' ;
oFCKeditor.Config["AutoDetectLanguage"] = true ;
oFCKeditor.Config["DefaultLanguage"] = "en" ;
oFCKeditor.Create();
sorry
I would appreciate it someone can tell me what the boo boo was.
Note: i specify the path as per the script displayed above.
(*Chris*)
(*Chris*)
I also have this problem and have managed to track how this error occurs, for my installation. If I choose any skin path other than default, this 'FCKLang undefined' js error occurs, however if your refresh the page, it loads without a problem. Once the browser has loaded the FCKeditor once, I can then revisit the page over and over, within the same session, and not experience any more javascript errors when the page loads.
I would really like to use the Silver skin, so I would like to know if there's a fix for this.
@import url( fck_contextmenu.css ) ;
from fckeditor.css in the 'silver' sj=kin folder this stops the error occuring - how you get the popups to be silver without this is another matter!
If I find out I will post here
Re: FCKlang not defined..
http://www.lookover.at
