It works fine the first time I load it. But if I remove dinamically the editor and add it again, it's not editable anymore. Toolbar is clickable and the textarea loads some text I insert with code. But when I click in the textarea nothing happens, no cursor, I can't write.
Removing and readding is a requirement. It works fine in all other browsers. I debugged with developer tools in IE and I see it executes removal and adding code well. No errors, warnings. I also started FCKeditor with debug window but it doesn't show anything either.
I also Looked in the DOM with developer tools, the iframe looks like usual, the body (where the text is written) has even attribute contentEditable="true". But anyways, I can't type.
Does anybody have an idea about this? Thanks in advance.
I am facing the same problem
I am facing the same problem mentioned above. Once the div containing the CK Editor is moved to some other divs dynamically and then when again try to use that div, nothing happens and also the text is gone. When the source is clicked in the CK Editor and again click on html then its back to its normal state.
If any one have solution for this please reply.
Same issue with Chrome New versions
I have also faced the same issue in chrome and i can see that the community have not make any reply yet...Please let us know the solution for it or we have to move to the Updated version (CK editor).
There is no solution for it
There is no solution for it besides upgrading. The core team will not spend time on an application that has been dropped years ago. Even CKEditor 3, besides the rare security fix, isn't getting any upgrades.
SKF 6203
I have had the same as the author's thinking, also talked about with the surrounding friends, this is indeed a question worth pondering. As a professional bearing businessman, I care about information of SKF 6203
have made me feel tired, read more articles like this or point of view, made me benefit a lot.In recent years, China's bearing industry has made rapid development, no matter in the quality, the scale, technology level, independent development ability and its economy has made great progress, but compared with foreign counterparts, enterprise scale is not big, strength is not strong, low product concentration, low product quality and development ability is quite obvious.
