hi there,
I have a list and i want to anchor each option in the list to content lower down the page, but I can't seem to get it working. I place the anchor where I want it in the content and then anchor the chose list item to it but nothing happens???!!
Can someone please help???!!
eg:
1) Test 1
2) Test 2
3) Test 3
Test 1
Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Aliquam tortor mi, mollis eu, varius ut, ultrices eget, neque. Sed hendrerit, lectus sit amet tincidunt rhoncus, urna tellus rutrum est, at gravida magna risus rhoncus metus. Praesent vestibulum. Nulla facilisi. Pellentesque non tortor ac ipsum porta mattis. Class aptent taciti sociosqu ad litora torquent per conubia nostra, per inceptos hymenaeos. Curabitur iaculis dignissim tellus. Donec in lorem. Quisque ac metus. Nullam gravida placerat velit. Praesent libero eros, porta id, aliquam vitae, ultrices ac, metus. Morbi pulvinar. Fusce luctus faucibus nibh. Aliquam eleifend eros ac leo. Duis ut lacus.
Sed mauris nisi, eleifend nec, volutpat vel, pellentesque quis, lorem. Nunc id erat vitae elit pellentesque blandit. Vestibulum aliquet tincidunt justo. Mauris quis leo. Curabitur adipiscing risus et ipsum convallis auctor. Vestibulum ante ipsum primis in faucibus orci luctus et ultrices posuere cubilia Curae; Nam facilisis felis non nisl. Nunc hendrerit eros tristique sem. Vivamus suscipit posuere quam. Vestibulum ante ipsum primis in faucibus orci luctus et ultrices posuere cubilia Curae; Donec in orci ut lectus pharetra adipiscing.
Test 2
Test 3
eg:
1) Test 1
2) Test 2
3) Test 3
Test 1
Test 2
Test 3
Re: FCK editor anchor links not working! Please help!
Test2
#Test2
FIXED: FCK empty anchor tags being removed.
If you make the code <a href="bob"></a> FCKeditor will eat it at it's first opportunity. Since this is perfectly valid code I'm pretty sure this was an introduced bug while trying to fix SF-BUG 1556878. They tried to fix the outcome not the cause and then removed perfectly valid xhtml in the process.
The easiest way to reproduce this is as follows:
1. Start an FCKEditor.
2. Go to source mode (in FCKEditor)
3. Type in <a href="bob"></a> (note nothing in the contents area of the anchor)
4. Go to WYSIWYG mode.
5. Go back to source mode.
You'll find that your typing has vanished.
Here's the fix. The source file is editor/_source/internals/fckxhtml.js in function FCKXHtml.TagProcessors .
If you remove the following lines the "expected" behavior returns.
The real code that gets run is editor/js/fckeditorcode_gecko.js and editor/js/fckeditorcode_ie.js .
It's a little tricky to edit this because the lines are huge. Remove the following text from both files and you'll be golden:
I suggest this code somehow makes it into the codebase as a fix. I have no idea where to submit it.
Jeffrey Hundstad
