Wondering if anyone has had this problem.
I have FCKeditor working perfectly well on the locahost machine. Then, when I transfer to the live site, I get a weird FCKeditor.
It's basically a hundred buttons that are repetitive and there's no textarea spot. I took a screenshot of the problem. It's attached.
Anyone gotten this error before or know why it could be doing this? Sorry, but I can't provide any worthwhile sample code at this time. I'll try to get some up soon.
Any ideas as to why this would work fine on local?
Re: Editor Problem...
I am using Coldfusion 7 on a linux server.
And I am looking at the page in IE 7
I get the same result whether I use the module include method or create a component object.
Many file calls expect the directory to be in the root. After extensive find and replacing I got it functional.
I'll keep that in mind, though.
I can change the base path to really anything I want...a garbage file that definitely does not include fckeditor code. It still shows the display image. It doesn't show the Server not found message I would get on localhost if the path was wrong.
Is this perhaps a .dll compile problem?? Switching environments is messing with the paths for whatever reason???
Just don't understand why it wouldn't show a broken fckeditor with the server not found page instead of the editor if the basepath is definitely wrong.
