I'm using FCKeditor 2.6.6 in Internet Explorer 9 under Windows 7 x64 and since upgrading to ie9, any dialog I open in FCKeditor won't display correctly UNLESS I switch to compatability mode. The dialog window appears, but is empty and can't be dragged/moved.
Thu, 03/17/2011 - 14:53
Re: Dialogs won't display in ie9?
Can you provide more information about the reasons IE9 is behaving this way? Which scripts in _source are concerned?
Since the team won't provide a solution, someone else could try.
Regards,
Koen
FWIW, our team has decided to deprecate FCKeditor based on the response above. We have found (or are finding) work-arounds to all the quirks in CKeditor since in several instances it behaves differently.
IE in general always full of bugs..ms build new version to add new bugs.
I recommend Firefox or Chrome to be used.
Paul Ellis
Many thanks!
http://ckeditor.com/demo
Absolutely agree. And as far as I know plugins for Firefix are more stable
