Hey,
I know the 2.6.5 release fixed the safari resize problem.
But a new problem is introduced when pasting text into editor. The text just disappears.
If I go into Source mode I can paste text, but that is as annoying as the resize issue.
Is this going to be an end of line release or bug fixes continue?
Anyone else able to reproduce, I have on multiple machines using safari.
thanks.
thanks.
Re: Copy paste & safari4 problem
Pasting into Safari wipes out the entire content area - the fix for safari resize must be related somehow.
Worst!
So our current options are either no cut and paste, or broken rendering.
I just created a ticket under the project trac detailing the behaviour.
To clarify it for this ticket, you must use the keyboard paste in Safari, and the behaviour is observed on a mac.
I can create a movie of the problem if that would be helpful. It's pretty severe, considering how important keyboard cut and paste is.
http://dev.fckeditor.net/ticket/4960
There must be something else required to trigger the problem or lots of people would be reporting the issue and since November there have been only three post reporting the problem
http://blip.tv/play/AYG76w4C
Is there a document that describes how to "build" fckeditor from an svn-checkout.
I cannot perform the above mentioned task without instructions as to how to test the checkout to see if it's broken or not.
I don't believe this problem exists in 2.6.4, so there aren't that many patches to look at really.
you have to pick only a revision then click on the "samples" link of that row and you'll get the code of that version right in your browser. I mean: you don't have to do any coding, just jump back and forward between the revisions until you find the first that works and you only need your Safari, nothing more.
On 07/27/09 11:27:11 there was a commit made referencing:
"Fixed #3481 : Fixed Fixed an issue in WebKit where paste actions inside table cells may leak outside of the table cell."
Prior to this fix, pasting worked fine. After this point, the pastes don't work correctly anymore...
what next?
