Hello
I installed FCKecitor, and tried to it in C#.
there is something called BasePath, which results a 404 not found in runtime. what will be the value of this property?
Thank you
Feras,
Thank you
Feras,
Re: BasePath Problem
I cant find the fckconfig.js in the whole package. Am using the one for .NET project.
Any idea?
Thank you
what about fckeditor.js ?
change the line as FCKeditor.BasePath = '/fckeditor/' ;;
FCKeditor and FCKeditor.Netdownload page
still getting base path problem
From the .Net zip, I copied the dlls into the bin folder of my web site.
From the other .zip I copied everything except the samples folder into my working directory.
I found that the .BasePath has to be "fckeditor/", not "/fckeditor/" because, when it assembles the virtual path you end up with two slashes // because of the leading slash.
.BasePath = "/fckeditor/" yields something like "mySite/myPath//fckeditor/editor/fckeditor.html"
.BasePath = "fckeditor/" yields something like "mySite/myPath/fckeditor/editor/fckeditor.html"
Hope this helps. Now if I could only figure out the virtual image path, and the image upload stuff.
Try adding
<appSettings>
<add key="FCKeditor:BasePath" value="~/fckeditor/"/>
</appSettings>
This worked for me.
Regards
Sai
The FCKeditor.Net: ASP.Net Control (FCKeditor.Net 2.6.3) only works with FCKeditor (FCKeditor 2.6.6 - "Our previous editor solution, stable and full featured") and NOT with CKEditor.
Al. Ceausu
what i must put in:
