When running fckeditor on Server I got the folloing error on
Line 3: <%@ Register Assembly="FredCK.FCKeditorV2" Namespace="FredCK.FCKeditorV2" TagPrefix="FCKeditorV2" %>
what I did:
I follow the "ASP.NET Integration documentation" and the editor worked fine localy on my machine .
After uploading it to the server - I't doesn't worked .
(Even try to run the solution on differnet computer localy and it worked well)
my web.config include:
<appSettings>
<add key="FCKeditor:BasePath" value="~/fckeditor/"/>
<add key="FCKeditor:UserFilesPath" value="~/uploads/"/>
</appSettings>
I found the fckeditor usefull and hope I can use it on asp.net 2 website I'm building.
I Would like to have your help with this problem !
Lior
Parser Error Message: Could not load file or assembly 'FredCK.FCKeditorV2' or one of its dependencies. The system cannot find the file specified.
what I did:
<appSettings>
</appSettings>
Lior
Re: ASP.NET Deployment problem
