Can someone confirm this problem?
It's driving me nuts..
Been using version 2.0Beta2 of the editor in UserControls in an ASP.NET app and everything works fine.
Upgraded to 2.0RC1 and can't seem to retrieve the Value property of the editor on postbacks? It always defaults to the initial setting.... Works ok in normal webforms (ie .aspx pages) but not in UserControls (ie .ascx)... Could this be something to do with the id of the control when used in UserControls, has something like UcControl1_FCkeditor1 ?
RE: 2.0RC1-Using editor in UserControl in ASP
RE: 2.0RC1-Using editor in UserControl in ASP.NET
I think i figured out what the problem is .. the source code for the FredCK.FCKeditorV2.FCKeditor has changed in RC1!!!!
In FCKeditor.cs file... if u change all references from this.ClientID to this.UniqueID then it works!
Possibly something to do with name & id's of Html elements can't be same..
There's also a minor problem with the BasePath property having a default setting of "/FCkeditor/", however the getter returns "" when the ViewState["Value"] is null thus when u set the base path of the control to the default, the actual BasePath will be an empty string not the default of "/FCKeditor/"!!!..
I've also made a few mods to allow for the use of "~" in the BasePath property.. here's my modified version:
namespace FredCK.FCKeditorV2
// [ System.Web.AspNetHostingPermission(SecurityAction.LinkDemand) ]
[ DefaultProperty("Value") ]
[ ValidationProperty("Value") ]
[ ToolboxData("<{0}:FCKeditor runat=server></{0}:FCKeditor>") ]
[ Designer("FredCK.FCKeditorV2.FCKeditorDesigner") ]
[ ParseChildren(false) ]
public class FCKeditor : System.Web.UI.Control, IPostBackDataHandler
private FCKeditorConfigurations oConfig ;
public FCKeditor()
oConfig = new FCKeditorConfigurations() ;
[ Browsable( false ) ]
public FCKeditorConfigurations Config
get { return oConfig ; }
[ DefaultValue( "" ) ]
public string Value
get { return (string)IsNull( ViewState["Value"], "" ) ; }
set { ViewState["Value"] = value ; }
[ DefaultValue( "/FCKeditor/" ) ]
[ Description( "BasePath of FCKeditor." ) ]
public string BasePath
get { return (string)IsNull( ViewState["BasePath"], "/FCKeditor/" ) ; }
set
if (!value.EndsWith("/"))
value += "/";
ViewState["BasePath"] = value ;
[ DefaultValue( "Default" ) ]
[ Description( "ToolbarSet to use." ) ]
public string ToolbarSet
get { return (string)IsNull( ViewState["ToolbarSet"], "Default" ) ; }
set { ViewState["ToolbarSet"] = value ; }
[ Category( "Appearance" ) ]
[ DefaultValue( "100%" ) ]
public Unit Width
get { return (Unit)IsNull( ViewState["Width"], Unit.Parse("100%", CultureInfo.InvariantCulture) ) ; }
set { ViewState["Width"] = value ; }
[ Category("Appearance") ]
[ DefaultValue( "200px" ) ]
public Unit Height
get { return (Unit)IsNull( ViewState["Height"], Unit.Parse("200px", CultureInfo.InvariantCulture) ) ; }
set { ViewState["Height"] = value ; }
public bool LoadPostData(string postDataKey, System.Collections.Specialized.NameValueCollection postCollection)
if (postCollection[postDataKey] != Value)
Value = postCollection[postDataKey];
return true;
return false;
public bool CheckBrowserCompatibility()
System.Web.HttpBrowserCapabilities oBrowser = Page.Request.Browser ;
// Internet Explorer 5.5+ for Windows
if (oBrowser.Browser == "IE" && ( oBrowser.MajorVersion >= 6 || ( oBrowser.MajorVersion == 5 && oBrowser.MinorVersion >= 5 ) ) && oBrowser.Win32)
return true ;
else
Match oMatch = Regex.Match( this.Page.Request.UserAgent, @"(?<=Gecko/)\d{8}" ) ;
return ( oMatch.Success && int.Parse( oMatch.Value, CultureInfo.InvariantCulture ) >= 20030210 ) ;
protected override void Render(HtmlTextWriter writer)
writer.Write( "<div>" ) ;
if ( this.CheckBrowserCompatibility() )
string basePath = this.BasePath.Replace("~", System.Web.HttpContext.Current.Request.ApplicationPath);
string sLink = basePath + "editor/fckeditor.html?InstanceName=" + this.UniqueID ;
if ( this.ToolbarSet.Length > 0 ) sLink += "&Toolbar=" + this.ToolbarSet ;
// Render the linked hidden field.
writer.Write(
"<input type=\"hidden\" id=\"{0}\" name=\"{0}\" value=\"{1}\">",
this.UniqueID,
System.Web.HttpUtility.HtmlEncode( this.Value ) ) ;
// Render the configurations hidden field.
writer.Write(
"<input type=\"hidden\" id=\"{0}___Config\" value=\"{1}\">",
this.UniqueID,
this.Config.GetHiddenFieldString() ) ;
// Render the editor IFRAME.
writer.Write(
"<iframe id=\"{0}___Frame\" src=\"{1}\" width=\"{2}\" height=\"{3}\" frameborder=\"no\" scrolling=\"no\"></iframe>",
this.UniqueID,
sLink,
this.Width,
this.Height ) ;
else
writer.Write(
"<textarea name=\"{0}\" rows=\"4\" cols=\"40\" style=\"width: {1}; height: {2}\" wrap=\"virtual\">{3}</textarea>",
this.UniqueID,
this.Width,
this.Height,
writer.Write( "</div>" ) ;
public void RaisePostDataChangedEvent()
// Do nothing
private object IsNull( object valueToCheck, object replacementValue )
return valueToCheck == null ? replacementValue : valueToCheck ;
Thanks!
I love you to
lyphtec is the best
