Problem number 1:
EditorAreaCSS is not having any effect, I have tried setting it relative to the root and as a full URL and it is not impacting the editor at all
Problem 2:
The browser/ uploader etc is loading up the .asp rather than .aspx versions. Firstly how do I correct this as I cannot test locally on .asp as there is no IIS installed on my pc and VWDE only supports .net. Once I have this correct, how do I set the path for the file uploads and browsing as there is no "config" for the .net as there is for asp
Many thanks
Problem 2:
Many thanks
