When using webkit-transform and Chrome with CKEditor the drop down menus can be hidden.
It seems that using webkit-transform can have unexpected z-index consequences which in turn hides the drop down menus.
The soloution is to add -webkit-transform:translate3d(0,0,0) to any element that might fall under this influence.
However the solution does not work when using the maximize button.
The request got lost in the
The request got lost in the laundry list of other stuff. It's a good idea to bump requests on occasion, to show devs there's still interest.
Bumping Requests
How does one "bump" requests?
Sorry, the bump thing was for
Sorry, the bump thing was for another post (had multiple tabs open). Here's what Reinmar (dev) said about your issue:
There are two options:
Yes. I can appreciate that a
Yes. I can appreciate that a test case is required. I spent some time trying to create one yesterday but as yet do not have a satisfactory one. I have been able to work around all but the maximize button case by adding the -webkit-transform:translate3d(0,0,0) fix to the higher level div. I am not sure that is satisfactory from a performance perspective but at least for now it gets it working.
I tend to agree with you that chrome is broken in this area. I dont see why higher level transforms should blow away the z-indexing below it.
I will see if I can carve out further time to generate a test case.
Regards,
Rob
