Hi everyone,
I am using CKEditor 4.1 for a project that intends to let users create web forms on their own.
However, the users are non-programmers and require customised form components. For example a textfield that comes with javascript that checks the input to make sure it is within a certain range.
I made the plugin and it works fine, but I can't edit the component after inserting it. I tried making a context menu by following the tutorial example but the textfield's original plugin programming will take control instead.
I tried disabling the plugin but it does not seem to help.
Any ideas is welcomed.
UPDATE
UPDATE
I got my context menu item working but I see two instances of the same thing.
The original textfield plugin is still activated when I try to double click on my custom component though.
