yes toolbar buttons selected like spellcheck are on the bar but don't showup to edit. on our site new setup all up to date..yet enabling on the fly spell checker does work. other buttons like justify won.t show up.
I created a new text format and selected same as full format options(tried all variations). I created a profile and added my text fornat. the profile itself shows up no where but in profiles config,
However when I switch to the new text format the profile with the buttons shows minus some buttons...like spellcheck. yet it is spellchecking in the text fields(I turned on the feature to test.. it can spellcheck). font's and styles button don't show but format button shows up NP...
any Ideas
drupal 7 ckeditor=7x.1.3 lib=4.3.3 this box I am typing in does have the spell checker button..(but not justify buttons) mine doesn't have either
seems like the buttons aren't supported in some way maybe I need to add some function?
to try to be more clear under full/filtered we get the spellcheck button. but not the justify buttons anywhere.
under the new text format I was not able to get justify or spell check. even though the buttons are in the "in use" area. and as I edit this post I cannot select justify from this site either.. which is really what we are after in the toolbar function.
so some buttons even thought they are selected and should be there don't even show up when editing
and yes I have cleared cache and tried several browsers.. again your bar doesn't have justified either
ok thanks for the input but,, maybe and mistake are not of much assistance. "It does work" i am sure of that. I have it working elsewhere. but in this instance it doesn't show some items. so I was asking if anyone knew of this condition. I have several browser on several systems to test with and this is unique for it to look this way.
When you say you are using
When you say you are using CKEditor 4, do you mean you are using CKEditor 4.0? Are you getting this on our demo site? Do you get any errors?
not working toolbar
any Ideas
update
thanks
Jaime
The toolbar works for me,
The toolbar works for me, maybe mistake is from your browser!
There are many factors that
There are many factors that could cause this. Make sure you have done the following:
I hope this helps.
this was very helpfull
this was very helpfull (things I didn't check) I will look around and get back when I figure out what threw this out of wack.
thanks
Jaime
