I recently installed the indent, indentblock and justify plugins. The justify plug in works great. The indent plugins work great (so long as I don't include the justify plug in). I expect to be able to place my cursor in the editor (or select a paragraph of text), click the indent button and have the text indent. It works fine so long as the Justify plugin is not added. Once I add the justify plugin, I can't get the indent button to enable.
This functionality works as expected in my now very old fckeditor setup.
Am I missing something?
Rich
The Indent and Justify
The Indent and Justify plugins are included in the Full package by default, and it's the first I hear of problems with having both. You would imagine more people experiencing this. Exactly which plugins do you add? Did you add the Indent / Outdent, Indent List and Indent Block plugins? Did you use the Builder? What do you do to get the issue (steps, maybe code), which browsers and which CKE version do you use?
