I use fakeelements for form fields, but I'm not happy with it. Insteed of using fakeelements I want to cover form fields with transparent images. My plugin changes the fields like this:
result from dataFilter.addRules:
<div class="coverdiv" data-cke-realelement="%3Cinput%20data-cke-saved-name%3D%22field%22%20type%3D%22text%22%20%2F%3E"> <img src="plugins/formcover/images/cover.png" class="coverimg" /> <input type="text" name="field" data-cke-saved-name="field" data-cke-processor="off" /> </div>
editor view mode shows:
<div class="coverdiv"> <img src="plugins/formcover/images/cover.png" class="coverimg" /> <input type="text" name="field" /> </div>
editor source mode shows:
Now what I need is offsetWidth and offsetHeight of the input field. At the moment I set IDs to my elements and use setTimeout getId(image).width = getId(input).offsetWidth.
Is there an easier way or a special cke way?
Found the solution. My
Found the solution. My coverdiv has display: inline-block, so I can do:
afterInit : function( editor ) { setTimeout(function() { var covers = editor.document.getElementsByTag( 'div' ); for(var i = 0; i < covers.count(); i++) { var item = covers.getItem( i ); if( item.hasClass( 'coverdiv' ) ) { var width = item.getSize( 'width' ); var height = item.getSize( 'height' ); item.getFirst().setStyles({ 'margin-bottom': '-' + height + 'px', 'height': height + 'px', 'width': width + 'px' }); } } }, 1); }
