Good morning! I am using ckeditor4's widget plugin to insert some HTML into the editor. The HTML is generated based on a selection made in a dialog.
The code is inserted fine, and if I double click in the white space in the editor, to the right of the HTML, the dialog reappears and the selection in the dialog is selected properly.
If I double-click on the HTML that has been inserted, nothing happens.
AFAIK, the double click functionality seems to be built into the widget functionality, so I don't know what I did to break it.
Any help would be greatly appreciated. I have attached the plugin.js file for the widget, saved as a txt file.
Kathryn
