I have ckeditor inline on a span. I need to apply style (say updating the color) to the selected element. When the user selects the entire block of editable text then I run this code:
style = new CKEDITOR.style( colorStyle, { color: color } )
editor.applyStyle( style )
The contenteditable object is wrapped outside by the new span. It should wrap the contents of the editable element. This is what it does:
<span style="background-color:rgba(40, 45, 7, 0.76);">
<span class="editable-element cke_editable cke_editable_inline cke_contents_ltr" id="the-editable-element" contenteditable="true">
some text
</span>
</span>
This is what it should do:
some text
</span>
</span>
Is there a way I can work around this?
Is this the best place to talk to the developers? Do they look at this forum?
Ben
I found my answer: http:/
I found my answer: http://ckeditor.com/forums/CKEditor-3.x/add-styles-links-instead-wrapping-around-links
I'm not sure it will work
I'm not sure it will work with span - try div instead.
For the background color you could add something like this to css:
.classsomething :hover { background-color: rgb(123,123,123); }EDIT: I didn't see you already found an answer :)
