Hello I have a problem with zoom plugin and new lines.
For example: I have zoom at body set to 1.1 and I go to the bottom of the document. Then I press enter a few times and cursor goes below visible area. Scroller is visible, but it doesn't scroll to the bottom. But then if I press one character, editor scrolls to the bottom. (you can manually add zoom:1.1 to the body of the content to simulate this behavior)
Any idea how should I resolve this? In my case, this is quite a blocker, because we have zoom enabled all the time.
Best redards
