In a middle of a updgrade, I'd forgoten to remove de adapter from 3.4 when installing 4.0. So... it worked!
I'd realized that when I was removing the old adapter and suddenly I received a jQuery error. So, you can copy the old adapter and write something like:
If you will check examples in the download package, there is an example how to make it work by just adding a class to textarea + including main ckeditor.js file.
We have a plugin which helps integrate CKEditor onto the page with jQuery, but it goes further and also integrated it with the form plugin (for ajax submissions) and the validation plugin.
I was wondering this aswell,
I was wondering this aswell, however the old jquery.js for 3.6 seems to work aswell for 4.0.
+1
+1
I've found a way... []
$('textarea.editor').ckeditor(function() {}, {skin : 'kama', toolbar: 'crToolbar'});
The configuration is available as usual, in the above example I've used a custom toolbar.
[]'s
Rafael Goulart from Brazil.
There is no need for that ...
CKEditor jQuery Plugin
Check it out: jQuery CKEditor Plugin
Or just use the official
Or just use the official jQuery adapter for v4. It's slated for CKEditor 4.2 but it's already available on GitHub:
https://github.com/ckeditor/ckeditor-dev/tree/major/adapters
Better integration with jQuery plugins
There are a couple of reasons actually...
1. Our plugin loads CKEditor dynamically.
Our CMS uses this to to better integrate CKEditor with our dynamically generated forms.
2. Our plugin overrides the $.fn.val() function as well as other plugins
jQuery Form plugin and the jQuery Validation Plugin, both of which we need to submit the form data via ajax.
