I'm having trouble in Safari 5.x when the main browser window is smaller than the spellchecker. The spellchecker window actually does center on the viewable document, but then the window get scrolled down so that you lose part of the spellchecker window. Here's what to do to reproduce:
- Open Safari 5.x, and reduce the window size so that a spellchecker window isn't going to fit it properly (probably 400px tall or so).
- Browse to http://ckeditor.com/demo#full and scroll down until you see the CKEditor controls.
- Click the Spellchecker button, then click Check Spelling.
This doesn't happen in Chrome, so I'm wondering if it's an actual bug in Safari or some possibly some code in CKEditor that is specific to Safari. that is causing the problem. If anyone can point me in the right direction to getting this fixed, that'd be fantastic. It wouldn't usually be a problem, but our content is in an iframe where the CSS overflow property is hidden and it's cutting the top of the document completely off without a scrollbar to remedy the situation. Thanks all!
