I'm using CKEditor for Joomla, editor version 3.0, Joomla release 2.5.9.
The buttons for the spelling checker ("Check Spelling" and "Spell Check As you Type" are not appearing in either the Advanced or Full toolbars, although they show in the toolbar configuration layouts. I've tried enabling SCAYT autostart, and adding the custom configuration "CKEDITOR.config.scayt_autoStartup = true;" but still not getting spelling checker.
Tue, 02/05/2013 - 03:00
You are using the Open Source
You are using the Open Source version of the component, aren't you? If so, there is a dedicated tracker for that: http://joomlacode.org/gf/project/ckeditor/tracker/
It would be great if you could submit your report there so that our developers could have a look. Thanks!
