Hi All,
I am a total newbiw to this, and can't even get the sample to work!
I can get the textarea, but as soon as the attempt is made to replace it with the editor I get a blank space.
Should the following work?
http://www.wetset.net/ckeditor/samples/replacebycode.html
What am I doing wrong?
Paul
It's ok now - my dumb mistake
It's ok now - my dumb mistake - when I unzipped the downloaded file I forgot to preserve all the subfolder names. Duh!
:-) Don't worry, these things
:-) Don't worry, these things happen! Thanks for posting back, perhaps this will help other who may stumble across the same issue in the future. Good luck with taming CKEditor and make sure you consult the Developer's Guide and samples for some clues!
