I have the latest version of the editor insertpre synatax highlighter I can place code snippets on the editor the are converted to htmlentities for example:
<p>example</p> is converted into
<pre class="brush:php;"> <p>example</p></pre> but when if I have a code snippet already in the textarea when the editor loads then
is changed to
<pre class="brush:php;"> </pre> <p>example</p>
How can this be prevented?
I've tried the following options but no luck.
config.htmlEncodeOutput = false; config.entities = false;
What I would like to do is create code snippets for tutorials using the editor, saving them is fine its editing existing ones that presents the issue.
