I've tried to install the pbckcode plugin. (Code Editor)
First I tried it manually. (Documentation https://github.com/prbaron/pbckcode/ ). I had a working installation of CKeditor with some other plugins. The new plugin has worked, but I've seen only the pbckcode-button. All the others were gone. Yes, I know the reason. My config.js contained only the configuration of the pbckcode. But I don't want to insert all buttons/plugins that I use manually.
Next, I generated a new CKEditor-Custom-Build with the plugin (Code Editor). I installed it. Now, all works fine, but the Code Editor doesn't appear.
What is the right way?
Do I really have to type everything manually?
