CKeditor works fine on my PHP-project.
But now, I try to load a piece of a page with ajax into a div area. This piece of Page is a complete Form with a textarea transformed by CKeditor and some other parts, without a header ... the teaxterea is shon but without the CKeditor-Elements. It seems, the JS doesn't work inside the dynamically loaded part.
The Main JS-Stuff is in the Header of the Calling Page. How do I get a call from the Calling Page to the FormParts in the called Piece?
PS. I'm using CKeditor4
Solution
Found the Solution, look at:
http://forum.jswelt.de/javascript/57202-verst-ndnisproblem-ajax-nachgeladenen-teilen.html#post363474
Have you tried using the
Have you tried using the Inline way instead?
inline
... yes, I tryed it. no way with the normal version. but the solution above makes also the inline editing working. the problem ist the <script>...</script> -area. It doesnt work inside dynamically loaded areas.
