Sorry for my english..
I used Ckeditor inline.
I have a problem when I want to add style. I explain, if i use the default style no problem but if i add my style, the toolbar works a halfs. In some blocs the toolbar works but not for each blocs.
I hope I was clear...
Have you an idea ?
Thanks a lot
Here is my code in config.js :
{ name: 'Titres Principaux',
{ name: 'Titres Principaux', element: 'span', styles: { 'font-family':'Monotype Corsiva', 'font-style':'normal','font-style':'normal','font-size':'200%','color':'#E05E25','text-align':'center' } },thanks
Did you check this guide?
yes, but i'can't copy my
Thanks for the answer
yes, but i'can't copy my complete code.
I have a message when submit: "Your submission has triggered the spam filter and will not be accepted."
So i follow the instruction on the document. I apply my style with elements "span"
I put my document with style
I put my document with style in attached file..
i have find solution...
I have downloaded TinyMCE.
