I'm having problems with icons showing up on a Firefox window that is opened using thickbox. If I open the frame by itself, the icons show up fine, but if I open the window using thickbox, the icons don't show up. I get lots of warnings in the Firefox error console, all apparently related to editor_gecko.css. It works fine in Chrome - the problem is apparently only in Firefox.
Fri, 06/21/2013 - 19:50
Exactly the same problem here
Exactly the same problem here. It seems to be related to HC detection - the affected editor has the "cke_hc" class applied. Removing that class with the web dev tools causes the icons to show up. Reloading the affected tab also causes the icons to show up.
Possibly related to Firefox bug #548397 - window.getComputedStyle() returns null inside an iframe with display: none.
FF25, CKeditor 4.2.2, Thickbox 3.1.
Reported as bug #11121.
