Dear all,
I've multiple (two or three) CKEditor in the same page but I have a problem with settings CKEDITOR.editorConfig in javascript.
I've need some CKEditor editable and same CKEditor not editable (in the same page).
I've defined two javascript, one with config.readOnly = false and one with config.readOnly = true.
But it seems that sometimes two different configuration in the same page are in conflict (it is happen for other things, different button in toolbar for example)
Do you have any suggestions to use multiple CKEditor in the same page ?
(some CKEditor editable and same CKEditor not editable)
Thanks for help,
Rinaldo
Have you checked the samples?
Have you checked the samples? It has a few examples of multiple editors on a single page. Don't forget to check the source.
Is it correct mode to have more CKeditor in same page with diffe
I've see the samples but I don't find that multiple editors on a single page.
However, in my (Zkoss) application I have written two configuration javascript files:
and
In my page, some CKeditor use config1.js, other use config2.js
My question is:
Is it correct mode to have more CKeditor in same page with different configuration ?
Rinaldo
Ya, it's actually recommended
Ya, it's actually recommended to use custom config files. More on this here. In the samples, there's no dedicated example. Examples have been scattered throughout various samples, like Magicline, Autogrow, Data Filtering (has a bunch), TAB Key-Based Navigation.
Including Two CKeeditors with different languages in one page
I would like to include two ckeeditors in my page with one using english language and the other one using arabic. how this can be done?
You would have to download
You would have to download CKEditor with both languages from this page. Then customize each CKEditor instance in-page by adding this code to your page's HTML after the textarea part:
</textarea> <script>CKEDITOR.replace( 'MyToolbar', { language: 'ar', toolbar: 'MyToolbar', });</script>Customer and Community Manager, CKSource
