I have tried recently CKBuilder to build a custom version of 4.x CKEditor.
I found some problems with package:
1. In line 948 there is code: console.log(a.container) what may prevent editor from work
2. Directory icons is missing in Codemirror plugin
See the package attached below.
https://www.dropbox.com/s/wtatemyljniit0e/ckeditor_4.1.1_9754c3f373a7.zip
Codemirror is a third-party
Codemirror is a third-party plugin. You should let the author know about this issue on the plugin's page or its dedicated forum page.
Are you sure it's Codemirror
Are you sure it's Codemirror's problem? When I download it from plugin page, not from CKBuilder everything's fine.
Are you sure that you're
Are you sure that you're downloading exactly the same revision of CM plugin? And that it is correctly written so it is possible to build editor with it (yes, plugin needs to be adjusted to work with CKBuilder)?
For 99.9% CKBuilder does not add console.log and for 99% icons are not missing because of CKBuilder.
