Hi
I am using version 4.3.1 and Chrome. If I am using the page
http://rev.ckeditor.com/ckeditor/trunk/7604/_samples/devtools.html
I can click the right mouse button anywhere in the textarea and I get the PASTE entry although the field has just one line of text and no other paragraphs following.
If I try this in my own instance I have the PASTE entry just in the first line of text, below this I get the context menu of the browser.
How can I correct this?
Thank you for any help
Urs
What you are describing is in
What you are describing is in fact a bug in CKEditor - http://dev.ckeditor.com/ticket/10169.
Perhaps workaround mentioned there will do the trick for you.
Wordaround helps at the beginning
Thank you very much!
