Hello! I was going to the use the CK Editor for my application. The data that is captured using the editor has to be shown in a report and the report allows me use only the RTF format and not HTML. Is there way I can get the data in RTF format from the editor. Or is there any suggested converter from HTML to RTF? Many thanks!
____________________________________________
- http://greenavis.com/
