HI,
I want to create custom toolbar buttons, which mimic some of the functionality CKEditor provide. For example, if i need to create custom button for "<B>,<I>,<PRE>,<H1>,<H2>" etc. tags, then how can i achive this?
I tried creating custom button for <PRE> tag, (the CKEditor "formatted" option), but it doesnt worked really well with EnterMode=BR
here is the plugin,
(function () {
/*http://blog.lystor.org.ua/2010/11/ckeditor-plugin-and-toolbar-button-for.html*/
var a = {
exec: function (editor) {
var format = {
element: "pre"
var style = new CKEDITOR.style(format);
style.apply(editor.document);
b = "button-pre";
CKEDITOR.plugins.add(b, {
init: function (editor) {
editor.addCommand(b, a);
editor.ui.addButton("button-pre", {
label: "PRE tag",
icon: this.path + "pre_btn.gif",
command: b
the problem is that, it applies the <PRE> to not just selected but to the entire text, when used with EnterMode=BR.
The CKEditor "formatted" option works well, it applies <PRE> tag to the selected text only and not to entire text.
Can anyone help me.
