Just trying CKEditor provided by cpanel and found that clicking LINK provides a dialog which will not go away. I have to shut down cpanel and start over. Must be my fault since I do not find any topic with the same problem.
Sun, 09/14/2014 - 20:25
Link help
Other dialogs have trouble also. Close, OK, esc, Northeast X -- none will make the dialogs go away. Using Explorer 11, Windows 7.
This is a third-party
This is a third-party integration (done by cpanel developers), so you would have to ask them about it. In particular: what CKEditor version they are using and if it's some older one, ask them to upgrade it. This issue does not occur on the latest CKEditor version that you can try on our demo site. IE11 support was introduced in CKEditor 4.3, by the way.
