I found a problem in ckeditor 4.1, when I customize the toolbar (config.js) and delete the item 'Format' in 'styles', the justification bar (left, center, right,block) does not work, it turns light gray and not linkable. Why?
Code:
config.toolbar = 'MyToolbar';
config.toolbar_MyToolbar =
{ name: 'document', items : [ 'NewPage' ] },
{ name: 'basicstyles', items : [ 'Bold','Italic','Underline','Strike','Superscript','RemoveFormat' ] },
{ name: 'styles', items : [ 'FontSize' ] }, // deleted 'Format'
{ name: 'colors', items : [ 'TextColor' ] },
{ name: 'paragraph', items : [ 'NumberedList','BulletedList','-','JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock' ] },
{ name: 'clipboard', items : [ 'Cut','Copy','Paste','PasteText','-','Undo','Redo','-','Scayt' ] },
{ name: 'links', items : [ 'Image','SpecialChar','Link','Unlink' ] },
{ name: 'document', items : [ 'Source' ] },
{ name: 'tools', items : [ 'Maximize' ] }
Just few minutes ago I have
Just few minutes ago I have commited a fix for this issue http://dev.ckeditor.com/ticket/10320
I guess that you use enterMode BR or DIV. Am I right? If yes, then next minor release (scheduled for next week) will fix this issue, In the meantime you can check the master branch.
Hi Reinmar,
Hi Reinmar,
yes, I use 'enterMode BR'... I'm waiting for the next release.
Thank you for support.
