I am using the image uploader plugin. It works perfect on Chrome, Safari, Firefox and IE8-10, but it fails on IE11.
The problem is an access denied on getFrameDocument function.
getFrameDocument: function () {
var i = this.$;
try {
i.contentWindow.document;
} catch (j) {
i.src = i.src;
if(c && b.version < 7) {
window.showModalDialog('javascript:document.write("<script>window.setTimeout(function(){window.close();},50);</script>")');
return i && new g(i.contentWindow.document);
The first call to i.contentWindow.document throws an exception but i.src = i.src doesnt fix it, throwing access is denied error.
This is the content of my iframe (weird) :
<iframe title="File" class="cke_dialog_ui_input_file" id="cke_47_fileInput" src="javascript:void(0)" frameborder="0" allowtransparency="0">
<html><head>
<link href="NewErrorPageTemplate.css" rel="stylesheet" type="text/css">
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>This page can’t be displayed</title>
<script language="javascript" src="errorPageStrings.js" type="text/javascript">
<script language="javascript" src="httpErrorPagesScripts.js" type="text/javascript">
</head>
<body onload="javascript:getInfo();">
<div class="mainContent" id="contentContainer">
<div class="title" id="mainTitle">This page can’t be displayed</div>
<div class="taskSection" id="taskSection">
<ul class="tasks" id="cantDisplayTasks">
<li id="task1-1">Make sure the web address <span class="webpageURL" id="webpage">//ieframe.dll/dnserrordiagoff.htm# </span>is correct.</li>
<li id="task1-2">Look for the page with your search engine.</li>
<li id="task1-3">Refresh the page in a few minutes.</li>
</ul>
<ul class="tasks" id="notConnectedTasks" style="display: none;">
<li id="task2-1">Check that all network cables are plugged in.</li>
<li id="task2-2">Verify that airplane mode is turned off.</li>
<li id="task2-3">Make sure your wireless switch is turned on.</li>
<li id="task2-4">See if you can connect to mobile broadband.</li>
<li id="task2-5">Restart your router.</li>
</ul>
</div>
</div>
</body></html>
</iframe>
Any help?
I am using version 3.6.3 and updating is not an option.
Then you have a big problem because the first version of CKEditor that it's compatible with IE11 is something like 4.2
Correct (4.3, actually), so
Correct (4.3, actually), so please upgrade! Keeping apps up-to-date is just good practice.
