I am using ck editor 3.5.2, I dont have to copy/ paste content in ckeditor in IE 11. Is there any way to solve this issue with out updating the version (ie, any patch etc). Thanks in advance.
I'm afraid this is clearly a bug in your environment or else you are doing something that you did not describe sufficiently to make us reproduce it.
All our demos (running CKEditor 4.3.3) work for me (and others) on Win 8.1, latest Chrome, Firefox, IE11. FYI, copying and pasting also works all right on other supported IE versions (IE8 and newer). We no longer support IE6 and IE7.
Instead of using some tools emulating browsers please try with a real browser because it's not the same.
Currently I am using the version 3.5.2 and there will be some technical issues to upgrade to 4.3. Is there any solution to solve this issue without upgrading the version?
Is there any patch available for solving this issue?
No, you are using a CKEditor version that was released over three! years ago, and its main feature was compatibility with Internet Explorer 9 RC... Microsoft changed a lot in their browsers and we released the CKEditor 4 line since that time, so you cannot expect there will be anything like a piece of code that you will copy and paste and it will work.
If you want to have Internet Explorer 11 support (and tons of other improvements and new features), upgrade to the latest CKEditor 4 version, period. See this article for more tips on how to upgrade from CKEditor 3 to CKEditor 4.
I also am having paste error when user with IE 11 wants to paste into CKEditor box. I want to upgrade CKEditor but I am using it in asp.net web page. The latest version I found on the download page was 3.6.4. Is it possible to get an update released? Or is it possible I can take the source code and follow some steps to make latest source work with asp.net?
that's true, the last CKEditor for ASP.NET release might have some issues in IE11 as it is based on version 3.6.4. We're sorry that we do not have any resources available right now to update the .NET control :(
Anyway, some users have already reported on the forum and elsewhere that they managed to replace CKEditor 3.6.4 with latest CKEditor 4 in the .NET package and that it works all right, so you can surely try that.
Since version 4 there are 3 official distributions available - Basic, Standard and Full. Visit the Download page, see what they contain and select the package that suit your needs. If you want to customize it, just go to CKBuilder and create a custom build.
Good luck and do post your results when your done, for others to read and learn. Thanks!
Nope. IE11 support was added
Nope. IE11 support was added in CKEditor 4.3.
IE still can't paste
ckeditor_4.3.3_standard.zip
OS Win 8.1 PRO
IE tester install-ietester-v0.5.2.exe
IE 11 64 bit
IE10, 9, 8, 7 via IE tester don't work
IE 6 via IE tester do work
Chrome and FireFox do work
Reproduce: paste in your sample window like this:
http://localhost:8080/umod/js/ckeditor/_samples/replacebyclass.html
Thank you all....
Thank you all....
Even When I using the
Even When I using the ckeditor 4.4 ist not getting, but if wait for three mins then its comiing.
upgrading ckeditor
Hi Anna,
Hi Captain America,
Hi Captain America,
A few pointers:
