Now my question is sanitizing ckeditor input and displaying it properly after saved
I am able to get the input and i can save it safely at database but i couldn't find
How to sanitize it to prevent XSS attacks and how to display it so it can be displayed as it is saved
Thank you
I will use it at asp.net site but asp.net version is not the latest one so i will use javascript one
And 1 more question. I want to disable all file upload features including image upload.
How can i disable it ?
Also is it possible to disable such as including link feature ?
And does CKEDITOR have quote feature ?
Ok additional questions
Assume that i directly stores the input got from ckeditor. But when i display it i always use ckeditor again.
Would ckeditor prevent client side xss attacks ?
Also how can i display output on client side by using ckeditor processing ?
You can remove any plugin you
You can remove any plugin you want by customizing your editor here. If you remove the image and linking plugins from your package, Advanced Content Filter will make sure none of the code goes through when someone wants to submit a link, for example. Please check the samples in the ckeditor/samples folder. You'll have many examples of filtering and stuff. The API is here.
