How can I enable the CKEditor for all textareas with class ".editor"?
This is a bit of a departure from the way the docs do it, but if you are using the jQuery library, this works pretty well (I haven't tested it very extensively, tho, so beware and test it yourself!):
// assumes ckeditor and jQuery are already loaded <script type="text/javascript"> $(function(){ $('.editor').each(function(e){ CKEDITOR.replace( this.id, { customConfig: '/jblog/ckeditor/config_Large.js' }); }); }); </script>
This worked on Win7, IE9 & Chrome, in my text environment.
tried jQuery?
// assumes ckeditor and jQuery are already loaded <script type="text/javascript"> $(function(){ $('.editor').each(function(e){ CKEDITOR.replace( this.id, { customConfig: '/jblog/ckeditor/config_Large.js' }); }); }); </script>This worked on Win7, IE9 & Chrome, in my text environment.
