Hello, We are using CKEditor 4 in our IPB, and we face one problem currently with the product. as we try to edit and update the existing text in the form, the alignment of the text changes to the left after we save the changes. this doesn't happen when writing first time. the change with the alignment happens when we edit the existing text. it moves to the left. We'd be grateful if you could help us with that issue. Thank you in advance
Sat, 02/09/2013 - 19:24
The CKEditor-IPB integration
The CKEditor-IPB integration was created by the IPB developers, not us. It uses a customized CKEditor version and we have no control over what's in there. As such, we are also unable to provide any support for this solution. You should seek help from IPB developers and community with that.
If it turns out that this issue is caused by CKEditor, the developers should create a ticket at our Development site. Good luck with solving your problem!
