I'm wondering why CKEditor does apply the formating to a whole paragraph and not just the selected bit. Can I configure that?
What browsers are supported?
Also, if I want to use it in an open source project which is partly commercial (having some paid extensions), which version can I use?
You can format part of paragraph
If I select a few words in a paragraph and apply bold or change size etc, it only applies to these words.
So it must be your configeration that is different.
I just used the demo. If I
I just used the demo. If I select a word and apply italic e.g. the whole paragraph changes also if I choose a formating like heading 1.
bolt etc works.
Heading 1
For heading 1 you need make a new line.
If you want to imitate a heading 1, the solution is to play with the font size of the words etc.
With italic the demo work ok on selecting one word for me.
http://ckeditor.com/demo
