I have searched high and low for an answer on this so I'm hoping someone can help. I am using the latest version of ckeditor on a Windows 8 development machine. I do have the autogrow pluging but I have disabled for the scenario here as well as set the max height out of pure desperation. I have the resize-enabled set to false as well. Here is my very basic config change...
CKEDITOR.replace('NewComment',{
toolbar:'Basic',
width:750,
height:80,
removePlugins:'elementspath,autoGrow',
autoParagraph:false,
resize_enabled:false
Anyway, when the page loads, the editor window is set to 750x80 as instructed with the proper menu items and configuration items being managed properly except when I click into the editor window. Immediately upon clicking into the editor window it goes fro 80 pixels high to 120 or so pixels high. Can someone please explain to me why it does this or if there is another plugin or configuration change I need to make in order to make it stop?
If you think you found a bug
If you think you found a bug you can always submit it to the dev site. Someone will have a look at it and either point you to an existing issue or close it with an explanation why it's not a CKE issue.
