I've built a custom CKEditor with the CKEditor builder. After uploading the files and including it in my website, the editor is not shown. When I'm using one of the standard versions, the editor is shown correctly. I've tried different version of custom-built editor, but every time the same. Is there any additional configuration that must be done, to get a custom-built editor working?
Best Regars
Pascal
You might be adding a third
You might be adding a third-party plugin that's not supported in the CKEditor version you're building. Check the version compatibility of each third-party plugin. Also try removing them one by one.
Thanks for your answer. I
Thanks for your answer. I seems that the Image Uploader Plugin causes the problem. Is there any other Plugin to upload an image when inserting an image?
