I changed this text to red, its gone.
Same trouble I'm having with my editor. What is the fix?
Ok.
Try to make this short. Have no idea wich version I have any more, Upgrade, down grade, new install, back to initial.
Heres' why. When adding color, changing size, url, flash, html, it all looks great; check the preview, looks great, click save, the only effect that stays in tact is bold.
ckeditor on another site I have works great, both php5, both sql myisam.
i think the working site is fkceditor 2
Might be ACF stipping your
Might be ACF stipping your tags. More on this here. Also, since you tried so many versions, might be a good idea to clear your cache.
before and after
don't see much on hepl in this version. Sure it's prob. simple, but ACF at http://cksource.com/
suggestions do not seem to be taking affect.
I'm an idiot, I dont get it.
So I guess the plan is to make fucntionality difficult
So I guess the plan is to make fucntionality so difficult to implement that we buy the full version, get 1 year of support, and maybe help desk can rectify the problems.?
I have installed the lastes, had same situation, and reverted back version 3 in an attemp to start at square 1....... Just completely unhappy.
Have you checked your backend
Have you checked your backend? I'm 99% sure it's not CKEditor stripping your markup. Those features work for milions of users, so I don't understand why do you blame CKEditor for that.
